Differential fluid change D1
Old Apr 25, 2010 | 09:55 PM
wynhd's Avatar
Default Differential fluid change D1
I changed the diff fluid my D1 yesterday, old oil was rotten smelling and a blueish green color, front took 2 quarts and the rear only took about 90% of the 2 quarts that is required, am I going to have any issues due to the inabilty to fill or top off with the 2 quarts that it takes? ( I was on level ground for the drain and refill. ) Also, doing the transfer case on Tuesday, any advice or is it pretty staright forward as I have read on the forum? Thanks for all the tips, would be lost without this site.
Old Apr 25, 2010 | 10:54 PM
kenk's Avatar
Yes, you should be fine- the owners manual says 1.8 qts for the front & rear diff. The t-case is easy and straight forward, as long as you got something to get the gear lube in. A quart gear lube bottle won't fit to the fille hole, requiring a pump or much smaller squeeze bottle.
Old Apr 25, 2010 | 11:43 PM
AK Rover's Avatar
If I recall correctly the drain and fill plugs for the t-case are behind the parking brake drum so it takes a little creativity to get the plugs and the ratchet out. Forget about getting the plug and ratchet out together.
Old Apr 26, 2010 | 07:48 AM
kenk's Avatar
Yes, the fill plug is half behind the drum. I had to get a wobble extension on my ratchet, or a breaker bar works.
kpl1228
Aug 10, 2021 08:51 AM
Athana
Jun 8, 2019 10:23 AM
weepit
Aug 14, 2012 07:57 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
