Differential Lock Light on
Moanin all.
Had a blow out yesterday morning at 5am on my way to work she blew her left front boot (tire). Got the tire replaced and Go to get back in the road and notice the Differential Lock indicator is lit. The shifter is in neutral and not engaged yet I can't clear the light. I was amazed that I had no problem getting the vehicle into all four positions with no hassles since I have not tried to since I bought the vehicle in December and I have no idea how long it has been before I had her.:confused
I have tried reversing with the 4wd in high and low and still cannot get the light to clear. I have search these forums and others and have not found a solution. I have also been searching the Rave manual. I guess I'm still learning how to use it as I'm not finding anything there. I did find information on a switch and how it works in conjunction with the ignition switch bat that was all.
I now will also have to re repair the damage to the right front sections of the vehicle that I had just repaired a few weeks ago from the dog incident.
Any ideas???
I am going to post in other forums as well and I know some of you are there too!!!!
Thanx A bunch.
The Goose
Any ideas???
Thanx A bunch.
The Goose
hahaha, thanks for calling us out Goose!! lol, just giving you a hard time.. I don't know man, I don't have CDL on mine so I wouldn't know where to start my friend!
Does it have to be in gear and dis-engaged for the light to go off? I know on mine, if the shifter is in neutral, I have a light on the dash that wont go off..
just a thought..
Regards,
just a thought..
Regards,
OOOOOPS after seeing the replies I realized that on this forum I do not have that info. DOH!!!!!!!!
98 D1, 162k miles, Poorly Maintained by PO. Have put new shock and u-joints, Put on 265/70/r16 wranglers yesterday. Had to remove ignition switch cause she ate and swallowed half the key.
As for Diff Lock Light. It had always been off before which acording to the OM means the differential is disengaged, Light supposed to come on only when you put it in any of the 4 positions.
The Goose
The Goose
Already tried that and it has not worked. I have seen something about removing the solenoid but thats if you can't put it into low or high. I think the problem is electrical. I have looked at all the vac lines I knew of. I'm also going to disconnect the battery for a bit and see if that helps.
The Goose
The Goose
