Differentials and computers
Old Sep 25, 2008 | 05:52 PM
73S3IP's Avatar
Default Differentials and computers
I heard mention on another thread that just because the ABS light is on doesn't necessarily mean that the ABS won't work. That got me to wondering, if the three amigos are all on, could all of those systems still work? Does the four-wheel drive system still work when they are on, or would the DII simply sit and spin onlythe wheel(s) with least traction in a muddy situation?
Old Sep 25, 2008 | 06:01 PM
Disco2Guy's Avatar
Default RE: Differentials and computers
The truck is full time 4wd. If you do the ABS test (panic brake at 35mph) and it doesn't work, then none of the other systems will since they work off the same system. That is why the CDL is still great to have in those loose traction situations.
Old Sep 25, 2008 | 06:30 PM
If all three lights are on then no, your trac control wont work, your HDC wont work and your ABS will work at a reduced rate.
When just the ABS light is on it means that one or more problems exist.
So your left front wheel may lock up in a panic stop while the other three wheels pulsate as they should for example.
So what you are hearing about the ABS still working even though the ABS light is on is not enterly true.
Having different wheels providing different levels of stopping power is a accident waiting to happen.
Old Sep 25, 2008 | 07:54 PM
73S3IP's Avatar
Okay, thanks. I understand on the ABS, Hill Decent, and Traction Control with regards to their not functioning properly if their lights are on. I was also trying to understand if these system malfunctions would cause the four-wheel drive system to malfunction - potentially leaving you stranded. It has been my understanding through reading that LR did away with the CDL because this "sophisticated" four-wheel drive system could somewhat simulate lockers at times as it senses wheel slippageand other conditions at each corner.
Old Sep 25, 2008 | 08:08 PM
The 4x4 will work as it should. The truck is full time four wheel drive, no computer controls the 4x4. You wont be left stranded.
If you wind up cross axled you will have to get yourself unstuck. Instead of the Trac control applying the brake to a spinning wheel which through pure mechanical pyshics transfers the power from the spinning wheel to the one with grip.
Your truck is full time four wheel drive, NOT all wheel drive, there is a differance.
Old Sep 25, 2008 | 11:30 PM
73S3IP's Avatar
Thanks. One last question on that note. When some of you guys install aftermarket lockers in these trucks, does that give the computer a hard time? I know Spike just explained that no computers control the four-wheel drive. I'm just trying to wrap my exhausted (from other things) brain around all the sensors and gizmos these LRs have in them and how they interact and handle modification.
P.S. I love this forum. I don't seem to have enough time to read everything on here, but I want to. I think I have found an information eutopia and new internet home! Thanks, guys.
Old Sep 26, 2008 | 07:34 AM
No lockers will not give the computer a hard time. The computers on a LR were added in after the fact.
The driveline on your truck is the same basic design that they used 60 years ago. Computers were a afterthought.
Maybe this will help.
http://www.discoveryownersclub.org/tech/history/
Old Sep 26, 2008 | 12:44 PM
Disco2Guy's Avatar
The locker will actually make it easier on the TC computer because it will think the wheels have traction, since they'll be spinning at the same rate when locked.
TheRealMW2Ninja
Jul 7, 2011 10:30 AM
booper169
Dec 3, 2010 11:09 AM
snafu
Sep 10, 2007 09:01 AM
redmel
Nov 14, 2005 09:03 AM
topgear
Jun 18, 2005 12:29 AM
