DII Manual Tranny???
I've driven lots of GEMS D1s with automatics and they've always been pretty unexciting. My '96 D1 with a 5-spd is a whole different animal and really puts a smile on my face every time I take it out. If a D2 with a 5 spd is similar, and easily acquired I'd take 2...
OK, somehow I knew "personal preference" wouldn't cut it for some Like several said, I find them wildly fun to drive, but they're also typically better on gas, give you a few more HP, provide another method of stopping (especially in inclement weather), and in all my wheeling adventures (mostly with Jeeps), I've never seen a manual tranny leave anyone stranded, even if a gear breaks.
But the car is a DD 1st! Never heard anything bad about Toddco until now, other than the fact that they've not replied to my e-mails that is. Only other bolt-up option I found was from RPI, and that's not what I'm looking for really. If the BMW would bolt up, use the same ECU(s), harness and so on, I'd be all over it. Not willing to retrofit anything...sgot to be drop in and work with everything. Like I said, it's a DD and I can't tear it down for 3 months, even if it is fun.
Mike, you doubt everyone who says they have a slipped sleeve...probably for good reason. I've replaced all lifters, oil pump and eliminated exhaust leaks. The sound is identical to those on YouTube (the guy who put his on the grill). My D2 only has 62K though and everyone else I've heard has 100-120K before they encounter this problem. Only solutions I've seen (drilling/tapping the liners) are not acceptable to me, hence the engine upgrade. I'd be happy with a 4.6L that had a tad more power (Merlin heads???) and no chance of ever slipping a sleeve again.
It's really only worth it (in my csae) if:
1. There is a direct bolt up replacement to be found in the US
2. Cost is < $3K
3. It's at least as strong as the stock AT
I'm hearing a resounding "no", so I'm content to press with what I got and hopefully it'll handle the extra power of a stroker kit when the time comes.
2. Cost is < $3K
2. Cost is < $3K
2. Cost is < $3K
