DII No start - suspect starter motor
Old Jan 30, 2017 | 03:24 PM
Luckyjayb's Avatar
[QUOTE=number9;594238]
The red lead to starter is supposed to be a cable. Looks like it was replaced with 12 or 14 wire sometime in the past. If as it appears it will lead to a shorter starter life.
......[/QUOTE
naaa there are two wires to the starter. The heavy 1/0 guage hot wire and then a small gauge wire with a black push on connector that goes to the solenoid.
Old Jan 30, 2017 | 09:45 PM
number9's Avatar
Aware there's a cable and wire. See after taking another look the wire is brown/red for the solenoid.
Old Jan 30, 2017 | 09:50 PM
Luckyjayb's Avatar
yea I think they just took it out of the loom but I get what you are saying now. Sometimes it's so hard to try n read what a person is trying to convey even when it slaps me in the face
Old Jan 30, 2017 | 10:23 PM
number9's Avatar
Yeah earlier when looking at photo all I saw was red and the control wire is brown on the WD. Went back and looked at diagram, then wire color codes and saw its B/R. When looking for B/R it no longer looked all red. One reason I prefer working on aircraft with all white wiring and wire numbers printed on each one.
Old Jan 31, 2017 | 08:07 AM
Luckyjayb's Avatar
yea I can understand that. Personally I don't mind color coded wire as long as it stays that color and is clean enough to differentiate.
Old Feb 9, 2017 | 06:09 PM
scottmb23's Avatar
So, after switching the spark plug wires between cylinder 1/2 I found the misfire problem, wire was severed from the connector..left it on cylinder 2 as I went to move back..Guess I have some new Kingsborne wires and a PITA job coming my way shortly..
Old Feb 9, 2017 | 07:07 PM
mln01's Avatar
I vote STI wires.
Old Feb 11, 2017 | 02:58 PM
scottmb23's Avatar
Ok, repaired the wire instead of replacing it, which by all accounts is a massive PITA. I used WD40 and slid the boot back, cut the plug wire a little to expose middle wire, recrimped and set boot back. Misfire gone, codes gone.
Old Feb 12, 2017 | 01:14 AM
Luckyjayb's Avatar
Great hope it stays that way for ya now
smokey847
Sep 8, 2015 08:55 PM
Roverman7
May 15, 2013 12:43 PM
rich
Freelander
Dec 22, 2012 08:11 PM
cinosweatz
Jul 5, 2012 09:50 PM
Robbo
Jun 15, 2005 05:03 AM
