Disabling the three amigos
Until I can truly afford the funds to resolve the three boys, is there a way to turn them off, other than having AAMCO doing it only to reappear again?
We already know it's the expensive route to takecare of it, but since running them on for the last year, it's not hurting the engine, just annoying.
RE: Disabling the three amigos
i dont know what the codes are but it looks like my abs works on all tires except the driver side front. thats the only one that locks up if i do a panic stop or if a accelerate really hard on wet floor. what do you think that could be? i have all 3lights on and my car is a 2002 d2 with 96k miles on it. i bought it with 83k and have no idea what kind of maitnence has been done to the car what are your sugestions
ORIGINAL: Disco Mike
How do you know what is wrong, what faults were found, do your brakes squeak? If you do a panic stop from 30 MPH, can you feel the ABS pulsate thru the brake pedal?
on
ORIGINAL: grussell
I have the 3 AMIGOS periodically. My brakes just started squeaking.
When I do the 30 mph emergency brake there is no pulsating and the 3 AMIGOS light up every time.
How mechanical are you? If you want to do your own brakes and save money get back to us so we can walk you thru this.
Don't let it go till the lights stay on, it will cost you an extra $100 or so to have the fault codes cleared.
on
ORIGINAL: chakadog
Ha. Just had codes pulled today on mine (year 2000). Definitely a shuttle valve problem. My mechanic said there was a diagnosis he could run that would determine if I need the "expensive" ($800) part or something cheaper.
Have your brakes been squeakling, if you throw a panic stop from 30 MPH plus, can you feel the ABS pulsate thru the brake pedal?
I can do the brakes. I have performed my own maintenance on all my other vehicles, but I am a new Rover owner so look to the forum for advice on particulars. I installed the Magnecores and Bosch plugs from recommendations from you guys and the results were good. What brand pads do you recommend? Any particulars about Rover brakes.
Garry
01 Disco SD 106K
Keller, TX
Garry
01 Disco SD 106K
Keller, TX
