Disco 1 4.0 fan clutch
Old Jan 26, 2010 | 06:56 PM
oljohnboy's Avatar
Default Disco 1 4.0 fan clutch
Does anyone know if there is another model engine that uses the same fan clutch as this one? Generally there are not very expensive, but the land rover seems to be. Any suggestions would be appreciated.
Old Jan 26, 2010 | 08:41 PM
antichrist's Avatar
http://www.discoweb.org/forums/showp...9&postcount=15
Will cost you around $60
http://shop.advanceautoparts.com/web...sku=19230027-P
That's the heavy duty one, there's a "standard" duty as well.
Old Jan 27, 2010 | 10:12 AM
okdiscoguy's Avatar
I think an XJ8 runs the same clutch, and the Autozone one is the one I am running. I would go with the one made for the truck. Mine kicks in a little too soon.
Old Jan 27, 2010 | 11:17 AM
antichrist's Avatar
Are you running the heavy duty or regular duty?
Heavy duty definitely engages more often.
Old Jan 27, 2010 | 11:43 AM
okdiscoguy's Avatar
I am running the HD, just like the one you posted. I would suggest the regular because it kicks in a little too often for my taste. Also takes a bit when it is cold...
Old Jan 27, 2010 | 12:27 PM
antichrist's Avatar
Actually I misspoke. The one I showed, Imperial/Hayden 215158, is the severe duty, the other one they carry, 215107, is the heavy duty.
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
