disco 1
Old Feb 28, 2007 | 01:19 AM
billinohio's Avatar
Default disco 1
second owner of a 95 disco, original owner took regular maintenance @ dealer, i'm not rich and don't mind turning a wrench. got the haynes manual but seems short on some topics. have replaced basic stuff, antenae, pads , rotors, fog lamps and tried to follow maintenance plan by the book. i have 125,00 miles and she runs great, was wondering if there are any particular isssues i might need to look for. have had her for a year and done regular stuff, oil, lubes and check fluids weekly. would enjoy any replys. thanks
Old Feb 28, 2007 | 11:14 AM
Default RE: disco 1
Here is a list i put together awhile back of things to do to a high miler to keep her up and running, if you have any questions get back to me.
Mike
RE: Disco Fluids - 1/16/2007 2:13:02 PM
No New Messages
Disco Mike
Moderator
Status: online This is the parts list for a 60,000 mile service the way I do it.
1 Oil filter , K&N 3001
1 Air filter
1 Transmission filter kit
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transsmission additive
1 Can of Spray Carb Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both od the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
