Disco 1 Overheated
Disco 1 Overheated
Yesterday the water pump on my '96 Disco 1 suffered a catastrophic failure. The water pump shaft actually sheared off while I was on the freeway. I pulled it over pretty quick ( I was on an overpass ), but it was hot enough that it died immediately at idle. This morning I started it cold ( after moving the belt and fan ) and ran it for ~20 sec. It started right up and ran fine but it sounded like there's valve clatter. It's never sounded that way before. I'm not sure if it's just sticking lifters or something more serious. Has anyone seen this before? I'm trying to determine what the condition of the engine is and whether or not it needs rebuilt. I know that Rover V8's don't take overheating very well. Is there a good set of checks to determine whether or not the motor needs rebuilt?
I didn't really read this at first. The thermostat and temp gauge stuck at the same time on my old 74 one ton Chevy. It started loosing power and smoking. I pulled over, popped the hood and oil was boiling out of the valve cover gaskets. The top hose exploded when I shut the hood. I figured it was toast. I changed the oil on the side of the road, replaced the top hose and pulled the t-stat, filled with water and I think it actually runs better now.
But yeah, like Mike said. Aluminum is a different animal...
No my work van has a cast iron block and aluminum heads, it is a Ford 5.4L, I drove through a big snow drift and all the snow under the hood pushed the serp belt off the pullys and then the crank pully shredded the belt.
My whole point was if the engine is toast then it is toast, but before you go pulling heads off change the oil first and see if it is still noisy.
HopeItsNotAMoneyPit
02-18-2015 05:18 PM
