DISCO 1 OVERHEATING
PANOS-Sorry that we are not much help, we are trying but we do not have that engine here in the USA, all we have is the 4.0 or the 4.6 V8 gas engine and it is different from your MPI 4 cylinder.
The thermostat should be on the engine where the radiator hoses connect. Most usually the top radiator hose, where it connects to the top front of the engine.
As far as the fan relay switch goes, we have no idea because you have a different engine and a relay can go anywhere.
Do you have a clutch fan attached to the front of the engine?
Have you checked to see if your radiator is clogged? If you have a clutch fan you wont overheat unless you are low on coolant or something is restricting coolant flow, like a bad thermostat or a clogged radiator.
We are trying buddy, dont give up on us yet. You know us American's, stuck in our own little corner of the earth.
Your English is fine, I am trying not to use to much slang either.
There really isint anyway to tell if the thermostat is bad by looking at it, it is a fairly cheap part to buy, make sure that you get the gasket too. And if you dont know the last time it was replaced then just buy a new one.
A clogged radiator...the inside of the radiator has little passage ways for the hot coolant to flow through and the air moving past the radiator from either the engine fan or moving down the road removes the heat from the coolant thus keeping the engine from overheating.
If the passage ways are clogged then the coolant cannot flow through them and then the engine will overheat.
They clog because of age, old/bad coolant. The best way to find out if it is clogged is to take it to a radiator shop.
You can drain the cooling system, remove the top and bottom hoses from the radiator and put a garden hose into the top of the radiator and see how well the water flows. It should come out as fast as you put it in.
For the short term you can remove the thermostat and put the upper radiator hose back without the thermostat in place and see if it still overheats.
ORIGINAL: panosdisco1
thanks for trying, you guys realy make me feel nice and comfortable in this forum.
sorry for my English as well..how can I know if the thermostat is fulty? I loosened it and it looks brand new. and also what does clogged radiator mean..
If you have never done it, Iwould flush and replace the coolant as well. If a lot of dirt and sediment comes out, there is a good chance that the radiator could be clogged.
You could put the thermostat in a pot of boiling water to see if it opens, then take it out and it should close.
