Disco 2 abs probs
Very often what a diagnostic tool reports as a wheel speed sensor (WSS) fault is not a problem with the sensor itself. It's instead a problem with the connector, where the sensor plugs into the wiring harness to connect to the SLABS computer, either in the engine compartment for the two front sensors or in the wheel well for the two rear sensors. This has been the case with my truck twice. In fact, some aftermarket sensors are also faulty.
The first time I replaced the sensor and the fault returned (right rear). I then learned about the problem with the connectors and spliced in a new connector. Still no luck. Then I removed the aftermarket sensor and examined it carefully. I could see a mark where it had been actually rubbing against the reluctor ring. I reinstalled the original sensor, with a new connector, and that corrected the problem.
I later had the same problem with the left front connector. Working room to reach the left front connector in a LHD truck is extremely limited, but I was able to pull the sensor-side wire back into the wheel well (including the rubber grommet) and install half the new connector with ease.
There's evidence that Land Rover recognized the problem with the connectors. New sensors from Land Rover have long wires meant to be routed all the way to the SLABS computer in the passenger compartment behind the glove box (LHD).
I've included a link below to the kind of "upgraded" connectors I used. You can also solder splice the wires and eliminate the connector, or some use simple 3M heat shrink butt connectors to make a permanent connection. I also found an inexpensive wire available at Home Depot with specs matching the original WABCO WSS wire that could be used to extend WSS wires. I've included that link below.
HIFROM 2-Pin Waterproof Electrical Connector with Crimping Tool
18/2 Gray Stranded CU CL3R Shielded Security Cable
https://www.homedepot.com/p/Southwir...3199/204725192
https://www.amazon.com/gp/product/B07BNFP79V/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Wheelspin (03-08-2021)
