ABS fault
Old Apr 8, 2009 | 01:17 PM
talbotracer's Avatar
Default ABS fault
98 Disco i changed the rear calipers and now i have a fault on the ABS the pedal goes hard or i get a very noisy rattle from the front can i fix it with out a computor
Old Apr 8, 2009 | 03:28 PM
You have a bad/messed up wheel speed sensor.
The noise you here is the ABS modulator pumping the brakes and the hard pedal is the ABS modulator working against you.
Since you just worked on the rear brakes check that wheel speed sensor and make sure that it is still seated properly.
06Range
May 8, 2013 09:01 PM
jmason
Mar 12, 2013 08:08 PM
anhernandez
Aug 18, 2009 12:47 AM
cottonpatchweims
Jan 14, 2005 01:59 AM
