Disco 2 Bottle Jack not working
Old Jan 26, 2013 | 02:21 PM
aguison's Avatar
Default Disco 2 Bottle Jack not working
I was finishing up my 3 Amigos repair on my 2003 D2 and getting ready to bleed the brakes... took my bottle jack from the engine compartment and to my surprise the jack doesn't work! (it doesn't want to raise up)
According to the Owner's manual, all you need to do is turn the thing at the bottom clockwise until it's tight and then start pumping
I did that and the jack would not come up. Is there anything else I should be doing?
According to some posts I read, there is a seal? that needs to be replaced and you need to fill up the jack with fluid?
As always any help is appreciated
Sincerely
Al
2003 D2
Old Jan 26, 2013 | 02:29 PM
ZGPhoto's Avatar
This has happened plenty, just buy another one at harbor freight or something.
Old Jan 26, 2013 | 02:46 PM
aguison's Avatar
They have those at Harbor Freight?
Old Jan 26, 2013 | 03:03 PM
No, Harbor Freight and Sears have much better bottle jacks for less money.
Old Jan 26, 2013 | 03:20 PM
aguison's Avatar
Thank you very much
Old Jan 27, 2013 | 06:01 PM
aguison's Avatar
Here is the bottle jack I bought from Sears
USD 17.00 2-ton capacity and fits perfectly inside the battery cover in the engine compartment. The factory tools fit the jack and work it well.
Notes:
1. However, the jack is short and does NOT raise high enough to get to the D2's jack mount points.
2. You will need two 2x4 pieces of wood to make it work and stow them in the back of the vehicle.
Regards
Al
Old Jan 27, 2013 | 06:04 PM
ZGPhoto's Avatar
Is it tall enough to reach the diffs? If so you're good.
Old Jan 27, 2013 | 07:19 PM
Michael M. Koch's Avatar
I found a Husky jack at Home Depot a few years back that also does the trick. And fits in the stock bottle jack location.
LRlax11
Apr 25, 2015 03:30 AM
maxman
Jul 23, 2011 03:15 PM
Street Wolf
Nov 20, 2008 01:13 PM
meltdowndave
Jun 13, 2008 08:45 PM
meltdowndave
May 31, 2008 01:10 PM
