Disco 2 CDL needed or not??
morning
hope alls well.
Ive recently bought a d2 2003 with no CDL
I’ve bought the parts to retrofit the CDL but a thought crossed my mind of do I need it?
I’m planning to overland the vehicle, the main trip being UK to Mongolia, is it going to be a case of better to have it than not need it, or would you say the stock D2 setup works well for what I will want
I do plan on taking the truck away from the tarmac at all possible opportunities!
i may have answered my own question but interested to hear whether stock is a good setup as is
(I’ve only had defenders before now so am used to the CDL but they had no TC)
many thanks
hope alls well.
many thanks
Received 1,189 Likes
on
This is the land rover Dll forum...so we know this is virtually impossible...lol.
Installed the linkage on my 01 and it was a game-changer. A hundred percent better off-road. It's one of those things...if you don't have it and never need it, you wouldn't miss it...but if you don't have it and need it...you'll definitely miss not having it.
Add it, you wouldn't be sorry.
Congrats, on your new rover...hope she treats you well.
Brian.
many thanks
many thanks
Brian.
I 'believe' that from late 01 to end of 03 there is no CDL transfer cases. If I am wrong I hope to learn so in this discussion. So if you have an 03, then you will need to find a new transfer case with CDL, and then the shift linkage.
I have a very early 01 and have CDL. It was very cool to engage it with a wrench and see the dash light go on, and have it work. Don't think I would ever have a Disco without it. One of the reasons I only look for 99 - 01 and 04s.
I'll be in a minority here--it all depends on how you use the truck. I had lockers in all my SUVs and I had to lock a rear differential only once. Yep. Only once in my off-roading life because most of the time I do overland travel that brings me to some rough spots but not where I can go only locked. Usually when I see obstacles, I get out and try to find the easiest route because for me the whole point of overland travel is travel and not terrain fighting.
99-01 for sure had the CDL Nipple, and "some" early 02 models (with either late 01 build dates or early 02 build dates "could" have it (anything with a build date past say 6/02 did not). 03 for sure in the US Market did not have a CDL nipple, however most US equipped 03 D2's had CDL compatible SLABS Units.
morning
hope alls well.
many thanks
hope alls well.
many thanks
Either way I am looking forward to seeing you keeping us all updated with your travels.
