Disco 2 does not crank. Need help
Hope someone can help.
Disco have been running “perfectly”. I just parked in a friend house and by the time I was trying to leave, car did not crank.
I know it is not too much info but maybe someone can help me with the diagnosis so I have a starter point.
Thanks a lot
- I already check and Battery is ok
- Car was unlocked with the key Fob (several times) to make sure it is not relate to the anti thief system
- starter does not even make a “click” sound.
Thanks a lot
You can jumper the starter relay, if you here a click or it starts your problem is upstream. You can jumper the two main lugs on the starter with a screwdriver, if it does not crank then you have a bad battery or starter. See if the horn will blow and headlights come on, if they don't you have a battery problem.
