Disco 2 does not crank. Need help
Old Nov 18, 2020 | 08:59 AM
san988's Avatar
Default Disco 2 does not crank. Need help
Hope someone can help.
Disco have been running “perfectly”. I just parked in a friend house and by the time I was trying to leave, car did not crank.
  • I already check and Battery is ok
  • Car was unlocked with the key Fob (several times) to make sure it is not relate to the anti thief system
  • starter does not even make a “click” sound.
I know it is not too much info but maybe someone can help me with the diagnosis so I have a starter point.
Thanks a lot
Old Nov 18, 2020 | 11:27 AM
mollusc's Avatar
What do you mean that the battery is OK?
Are the battery terminal connections clean and tight?
Does the dash light up like normal when you turn the key?
Old Nov 18, 2020 | 06:26 PM
Extinct's Avatar
You can jumper the starter relay, if you here a click or it starts your problem is upstream. You can jumper the two main lugs on the starter with a screwdriver, if it does not crank then you have a bad battery or starter. See if the horn will blow and headlights come on, if they don't you have a battery problem.
Manbeer
Jul 2, 2017 10:35 PM
pb&jnyc
Aug 5, 2015 06:51 PM
vette427sbc
Sep 18, 2014 03:55 PM
jisenb
Dec 21, 2013 02:55 PM
mooal5
Mar 5, 2008 01:34 PM
