Disco 2 engine noise and hesitation
Old Oct 25, 2024 | 02:48 PM
jacollins's Avatar
Default Disco 2 engine noise and hesitation
My 2003 automatic V8 petrol disco has quite a lot of engine shaking/hesitation, and has recently developed a misfire/splutter which sounds like it’s coming from the engine, when I start it up from cold. The splutter then stops after a minute.
I also have a slight rattling/whining sound when I accelerate up hill or through 3000 rpm. The acceleration also jumps about about up hill and lose power a little bit.
I’ve changed spark plugs, ignition wires and coils, and engine oil, and checked all fluids. I had the mechanics check everything they can see, and no luck.
Any ideas where I should look? It’s been suggested it could be fuel injectors, intake manifold or exhaust manifold, but I have no idea where to start…would it make sense to get the fuel injectors cleaned and then gaskets for the rest all checked at the same time?
Old Oct 25, 2024 | 04:36 PM
Extinct's Avatar
Are you taking it to a LR specialty shop? We don't recommend every taking a LR to non-LR shop, they usually do more harm than good.
Old Oct 25, 2024 | 10:40 PM
jacollins's Avatar
I’m in Georgia (the country) and don’t have the luxury of finding a LR specialist.
If I did get them to clean/check my fuel injectors, it might not be much more to change some of the gaskets? Labour is cheap here, and I can buy the parts online so won’t cost a fortune
Old Oct 26, 2024 | 01:17 AM
Richard Gallant's Avatar
check your fuel pressure
Old Oct 26, 2024 | 05:07 AM
Extinct's Avatar
Ok, we understand your situation better now. As you did not mention it we will assume right now the check engine light is not on and you do not specific misfire codes. If you do have any misfire codes those would be a big help. The other thing I would do is chart the oxygen sensor voltage with an analog device that can measure voltage via the OBD port. If you don't have one I would recommend a low cost ELM327 bluetooth device combined with the free torque app for Android. You can see a video of what charting the voltage looks like here
This will tell us if the engine is functioning normally with respect to fuel mixture.
Old Oct 26, 2024 | 04:26 PM
jacollins's Avatar
Super helpful, thanks. I’ll measure the oxygen voltage like you said.
additional info - I had the cat converter removed 18 months ago as it was no longer working, so the check engine light is always on. Mechanic said no error codes are showing but can double check when I go back.
how do I check the fuel pressure as suggested?
Old Oct 26, 2024 | 06:06 PM
Extinct's Avatar
Don't worry about the fuel pressure until after the oxygen sensor voltage is tested. The ELM327/Torque app will check codes also.
Old Oct 27, 2024 | 04:40 PM
Harvlr's Avatar
I think if your CEL is on, you will have a fault code. Assuming it’s your downstream O2 sensor, it’s easy to cancel.
Old Oct 27, 2024 | 11:27 PM
jacollins's Avatar
I’ve ordered a Veepeak Orb 2 Bluetooth scanner. Should arrived in two weeks from the US and then I’ll run the checks and let you guys know what I find!
thanks
Old Oct 28, 2024 | 07:11 AM
The Deputy's Avatar
You had the cats removed permanently?
