Disco 2 ignition locked
Old Jul 6, 2020 | 04:46 PM
RayofSunshine96!'s Avatar
Default Disco 2 ignition locked
The first time I took my land rover discovery 2 out somewhere I locked the door and accidentally set the alarm system off when I unlocked it. We had to tow it back and it’s now been a couple months of research and trying things to fix it. We can disable the alarm but we can seem to get the ignition unlocked. We’ve tried the 1515 thing but are not sure what to do after. Any help would be greatly appreciated
Old Jul 6, 2020 | 06:33 PM
Extinct's Avatar
More details needed, does the ignition switch turn? Lock and unlock the truck 3 times with the fob or key, try that.
Old Jul 7, 2020 | 04:26 AM
JUKE179r's Avatar
Welcome to the forum.
Old Jul 8, 2020 | 02:52 AM
jdbayer's Avatar
So there isn’t a lot of information here. If the key won’t turn at all it could be the steering lock is stuck. Wiggle your steering wheel right and left while you turn the key. Absolute worse case you could remove the black casing and pull the tumbler and see what is going on. If you can figure it out you could replace the key with a push button start. I did it to mine and it works great. We do not have a chip in our keys so it is a fairly simple conversion. A push button/remote start is only about $60 on Amazon and it is really easy to install.
Mountain Goat
Aug 30, 2022 11:08 AM
dirtydiscoparty
Mar 18, 2017 06:48 PM
CrossRover
Aug 12, 2016 10:44 PM
popplestones
Jul 13, 2016 12:52 AM
Kcid1101
Jun 11, 2013 10:19 AM
