Disco 2 issues
Disco 2 issues
Hello I was told to post here
I just got a 04 se disco 2
121k miles
Having some issue
Engine revs great has no milkshake
It doesn't seem down on power but struggles to accelerate to hwy speeds just revs up and almost like it being held back?
Got code for spark plugs misfire ,maf,02,fuel pump, the air injection appears to have been deleted , coolant throttle body bypassed has been done .
Also didn’t appear to be vacuum leak, I pulled some vacum lines off and wouldn’t hardly run.
I have ordered the full tune up kit plugs ,wire
new crank seal - old one leaks
cps sensor
All
02 sensors
121k miles
Having some issue
cps sensor
All
02 sensors
I don’t know if there’s a definitive way. Mine were rattling and I found out they were plugged when I removed them. (It had way more power after). To really test them you would need to disconnect the pipes and then try to blow air through them, but I have no idea how you would know what’s normal. Maybe a muffler shop could test them? But this is only one idea. I think some other people with more experience on this issue will chime in here.
Ryanok (11-18-2022)
If you're doing plugs are wires, coils probably wouldn't be a bad either at the same time. Which usually means pulling off the upper intake, so you'll need a gasket set.
Fuel pump code is odd. You might want to get a Rover-specific code reader so you can get more detail on what's actually going on, as well as read transmission and body codes.
longtallsally (11-19-2022)
I thought they could. I’m almost sure I read it in the UG documentation. Also saw this thread:
https://landroverforums.com/forum/di...or-1-f-108338/
