Disco 2 issues
Old Nov 19, 2022 | 08:23 PM
Ryanok's Avatar
Fixed it , I cleaned the maf sensor, new plugs and wires , changed transfer case fluid now it runs like a rock star .
also added sea foam and will do a oil change in a couple hundred miles.
Old Nov 19, 2022 | 09:17 PM
Harvlr's Avatar
Ryan, great news!
Longtallsalley, I’m definitely not an expert on this. My understanding is that the downstream O2 sensors look for a difference from the upstream sensors. If there’s a difference they’re happy. In the case of my Dakota I drove it for a few years with plugged Cats and they never threw a code. I was always disappointed with the power of the vehicle, but I assumed that it was normal for the 4.7. After I removed the Cats, I would get a fault from the downstream sensors once or twice a year, but it had way more power.
Old Nov 20, 2022 | 06:37 AM
Ryanok's Avatar
Thanks I picked it for $2500 day before yesterday wholesale dealer bought it from a local girl in town it was her dads for several years , he got scared after I pointed out the leak also needed bumpers the plastics broken on them and needs a crank oil seal and had a few scratches, interior is real nice, everything works but I bought it with the intention of doing a motor swap and raptor lining it , the car is super clean 121k miles I think original , some frame surface light surface rust .
someone has done the -bypass mods: air injection and the throttle body coolant bypass found yesterday during the tune up.has some 265/65/18 tires need replaced bad.
My question is do the 04s have the issues the earlier ones have?
Old Nov 20, 2022 | 09:34 AM
JohnZo's Avatar
Cool Pluggage
Originally Posted by Ryanok
I wonder how to check that ?
Great news that it's running good again. A little TLC goes a long way on our Rovers.
An easy way to check for plugged cats is with a pressure gauge. Measure pressure at the upstream O2 port. My mechanic says if it is more than 2 or 3 psi, at low or high revs, then there is pluggage. Not sure if pluggage is a real word.
I noticed one day that the cats on my 94 had little patches welded. Turns out the ceramic got removed, so I don't worry about pluggage.
Old Nov 20, 2022 | 09:37 AM
Harvlr's Avatar
Thanks for that John. It’s nice to have an actual test for plugged cats.
Old Nov 20, 2022 | 10:03 AM
longtallsally's Avatar
That thing looks like a good place to start! And that is how the Disco love for idiots like me and others around here start: buy one that looks great, but has all the issues from neglect over a number of years/owners.
You’ve got a long road to recovery for it, but once you learn all this stuff, it’s so cool to get one to a great place at a fraction of the cost of a newer machine. It has 80% of the luxury/capability/comfort as a newer machine, while at the same time retaining a nifty vintage look.
Old Nov 20, 2022 | 11:45 AM
Ryanok's Avatar
Update the t case is leaking I used atp 215 with new synthetic diff oil and seems to be leaking worse now .
Just Found all three breather pipes were burnt closed
Old Nov 20, 2022 | 04:56 PM
Extinct's Avatar
Known wear issue. Cannot repair it without removing tcase from transmission. You an run 90w140 and it will slow down a little. I wouldn't worry about it unless it is a very serious leak
Old Nov 20, 2022 | 05:53 PM
Ryanok's Avatar
Highest I can find is 85/140
Old Nov 21, 2022 | 06:14 AM
Extinct's Avatar
Close enough
