Disco 2 quits running
Old Dec 15, 2008 | 05:31 PM
dragon_avaloch's Avatar
Default Disco 2 quits running
This morning, the Rover died after traveling @ 7 miles on highway, died while waiting for light to change a few min later. We had it towed to a shop down the street, got it off the flatbed, they turned the key and it fired right up. We drove it home 7 miles on the highway and 2 miles stop and go to our house, no problem. After 15 min, tried to start it to go to grocery store, turns over but, again will not start. Fuel pump or crank shaft sensor? How would I check either item? Or could it be something else. It doesn't have any hesitation prior to stalling.
Old Dec 15, 2008 | 05:43 PM
Default RE: Disco 2 quits running
Bad crank sensor. No way to check it, either it works or it doesnt.
www.atlanticbritish.com
When it gets hot it will fail, eventually it will fail completly.
Old Dec 15, 2008 | 05:54 PM
Are you certain, fairly sure. I'd like to make sure before ordering an $80 part that I don't need. I just started it after sitting for @ 1 hour and pulled it into the garage. No problems starting.
Old Dec 15, 2008 | 06:12 PM
I cant be 100% sure from here.
But it is a high failer part for DII's.
When it is acting up you need to check for spark, then for fuel PSI at the fuel rail, then replace the crank sensor when all else is good.
Old Dec 15, 2008 | 06:15 PM
jkid's Avatar
pull it out and take a look at it. If it's covered in shavings, oil or looks heat scorchedI would just replace it. If it's never been replaced I would do it anyways, they tend to fail. They are about $80 at the dealer usually. You can check it if you're good with a volt meter, it should fluctuate if it's working.
Old Dec 15, 2008 | 06:17 PM
OK, thanks. Next question. AutoZone has it for 59.95 w/2 year warranty and I can have it tonight. Any problems with using AutoZone parts?
Old Dec 15, 2008 | 06:22 PM
OK, just to test the warm-up theory, I had it running in the driveway and it just turned off after 10 min.
Old Dec 15, 2008 | 06:26 PM
jkid's Avatar
Def. the sensor. It's right next to the exhaust and the heat probably causes it to fail from inc electrical resistance.Not sure about the autozone sensor, but that'sa pretty important partto buy cheap, could be good though
Old Dec 15, 2008 | 06:29 PM
sloppyjoe's Avatar
again the sloppyjoe rule must apply,,,
skimp on your wife or girlfriend NOT on your rover
Old Dec 15, 2008 | 06:31 PM
Thanks for the info.
