disco 2 self leveling susp
Old Feb 1, 2009 | 08:09 AM
fourwheel's Avatar
Default disco 2 self leveling susp
hi guys coming to you from africa have a problem just installed a aux wire to me fridge in rear connected it from fuse box in engine bay+- did briefly touch[yes i know how stupid that was]but now self levelling has dropped to bottom light on the dash im leaving for deep bush on thurs 5th so no time to get to adealer[far aaway]can i replace rear airbag and shocks with standardshocks and coils for the trip????
Old Feb 1, 2009 | 08:25 AM
Default RE: disco 2 self leveling susp
Yes you can, the SLS is a common problem with DII's and one of the fixes is a coil convertion.
Here is a link as to what you will need, I know you cant order from these guys, but they list the parts needed so that you can pick them up locally.
http://www.roverparts.com/Parts/9268D2ABP.cfm
Old Feb 1, 2009 | 08:49 AM
unimoged's Avatar
Where are you located in Africa, are you near a large city where you may find a salvage yard. You can use the rear springs and seats / bolts / etc. off of any DII with the regular spring rear suspension. The lights will remain lit in your dash but the DII will be level.
Spike555, how different are therear springs on a DI when compared with a DII. Can they be retrofited and used temporarily.
Good luck.
Old Feb 1, 2009 | 09:20 AM
ORIGINAL: unimoged
I am pretty sure that for a trail fix it could be done, but DI's and DII's have different spring rates and the truck would def ride funny.
It would be best if he could use DII springs
I do not know if the spring seats are the same size for the two trucks or not.
Old Feb 1, 2009 | 09:32 AM
Before you go changing anything, have you checked "BOTH" fues for the SLS, # 28 which is a 10 amp fuse under the steering wheel and the is a 30 amp, I believe in the enghine compartment fuse block? Is your SLS warning light on?
After checking both fuses, and knowing they are good, disconnect the positive battery cable for about 15 seconds to see if it will clear the system.
Then if all else fails, look for some used coils and plates, you won't need to replace the shocks.
Mike
echo46
Oct 19, 2020 12:13 AM
NESkier
Mar 1, 2015 06:59 PM
clockmaker21
Oct 10, 2009 09:09 PM
robdis96
Jan 3, 2008 02:54 PM
dailyuser
Dec 31, 2005 06:22 PM
