Disco 2 won’t start again!!
OK, just to be clear, there is a Cam Position Sensor (CPS) on the front of the engine and a Crank Position Sensor (CKPS) on the back. Are both of these new? You mentioned CPS above but I don't see a mention of a CKPS. I'm not sure if both of them would cause the same behavior however the ECU uses both of them to determine spark timing and fuel mapping. The ECU is located in the passenger footwell (US vehicles) behind a black trim panel. You should get a copy of the RAVE if you don't have one.
Well, I don;t really know. Could be a simple loose wire on a knock sensor. Maybe the cam pos sensor.....these issues can be a real PITA to track down. One member replaced his driver fuse block to fix an intermittent electrical issue... just do one thing at a time... maybe a harness issue going to the coils....
Hi guys. Still trying to find what is going on with my disco 2. Today I cleaned the hell out of the grounds, found one with a lot of rust and clean it pretty good. Still no start... exactly the same issue as before. I sprayed some starting fluid in the intake and nothing, clean the idle control valve again and throttle and nothing. Swap batteries for a fairly new one that I have on my other car, still no start. I think it have to be some kind of electrical issue. I got spark and fuel pressure. What is going on with this car?! I really love it but I really don’t know what else to check. Camshaft position sensor? Starter? Another thing I noticed is every time I crank the truck I got a strong smell, kind of a gas smell. Any thoughts?
If you had spark then it would have stumbled with the starting fluid. You said earlier you replaced the Cam Position Sensor (front of the engine), but you haven't touched the Crank Position Sensor (back of the engine opposite of the starter) correct? You will not have spark or fuel if the Crank Position Sensor does not see the engine turn over.
carlosrecio123 (06-25-2020)
Hi guys, I just replaced the crankshaft position sensor. The one in the back of the engine. I haven’t touch the camshaft sensor. I looked at it today and that area looks very dirty and hard to reach. What the truck does is just crank and crank and no start at all. Not even sputtered when I put starting fluid. You guys think a bad MAF sensor will do that? Right before she died on me she was stalling a lot at idle and I could notice a little loss of power. All this happened overnight, one day she was great and the next one she start acting up.
