Disco 2 won’t start please help
Just checking - are you sure your truck is not immobilized? I had something like that happen when my battery went out. It would have nothing to do with misfires though.
just to confirm, you have verified fuel (starter fluid) and verified spark - correct?
Still need to check for spark. Starter fluid didn’t started the truck. Just put a little in the throttle body. Don’t know if I did it correctly. I haven’t check the fuel pressure but I press the fuel valve on the fuel rail and it sprayed some gas. Man this truck is getting my nerves lol.... how do I know if the truck is immobilized? I recently started to use a keyfob that someone programmed for me because I lost the key that open the door. The key of the ignition is different, I guess the previous owner change the key ignition.
Ok - don't want to send you off on a tangent - immobilization is a security feature of these things and one of the things it does is kills the fuel to the engine. But lets not go done this path until you have verified spark and fuel pressure.
These trucks are pretty cool but you have to find troubleshooting interesting otherwise they will cost you lots $$$ having someone else do the work for you. Good luck.
Spark should be easy - pull each wire one at a time, insert a spark plug and stick a screwdriver against it. Have someone turn it over and look for the spark. Or you can get one of these tools.
