Disco 95 ECU
Old Aug 11, 2009 | 03:07 PM
conksss's Avatar
5th Gear
Default Disco 95 ECU
Hey im trying to fix my 1995 LR Disco and it backfires since it is running to rich. none of the lights or anything work inside the vehicle either. i need to replace some fuses im sure, but i just replaced the airmass intake. i think i need a new ecu but i am not sure where it is located on the car. can anyone give me some help. thank you
Old Aug 11, 2009 | 03:30 PM
lipadj46's Avatar
How many miles? octane gas used? What wires and plugs/how old? What fault codes are you getting?
Old Aug 11, 2009 | 03:41 PM
conksss's Avatar
5th Gear
Default ecu
it has about 115,000 miles on it and i used 87 octane. i replaced the wires and i think the plugs are good. it hasnt been on the road for about 2 years. last time it was on the road it blew out both cats in a bout a week after getting them replaced. i dont have the computer codes yet but i have to replace the 100amp alternator fuse which i just saw was blown. it idles fine but when i put it in to gear it starts that annoying studder. i just had the tranny replaced also so i dont know what is left to fix besides the ecu. any thoughts?
Old Aug 11, 2009 | 03:42 PM
conksss's Avatar
5th Gear
Default ecu
where is the ecu located on a 1995 disco anyway?
Old Aug 11, 2009 | 03:58 PM
lipadj46's Avatar
Back right side (passenger) of engine bay.
Old Aug 11, 2009 | 04:02 PM
Its not the ecu.
First things first, you MUST use premium gas, if you dont you will have severe run issues.
You need to replace your spark plugs and your cap and rotor.
After that you will need to set your ignition timing, I would highly recommend having a shop do that for you.
Once your ignition timing is set I bet she runs like crap because of the 2 year old gas in the gas tank.
With the engine timing off it will back fire really bad and can easily destroy your cats.
Old Aug 11, 2009 | 04:49 PM
llPANCHOll's Avatar
Originally Posted by Spike555
Its not the ecu.
What he said..
Paul Grant
Aug 10, 2014 12:29 PM
nwaneal
Dec 10, 2010 05:07 AM
DZACKERY
Oct 13, 2008 02:17 PM
Phototone
Apr 8, 2008 04:10 PM
