Disco Bttery
The RAVE spec is 72 amp hour, but in selecting a battery you want to also consider getting the largest CCA (cold cranking amps) number, when deciding between the basic and higher priced battery. And putting in a larger amps battery is fine as long as it fits in the space, and teminals don't come close to touching the hood. The 130 amp alternator is running the truck and can handle two batteries.
Plan on a new battery every three years. It's built to fade, battery companies also build ones that will last 20 years that are used by the phone company. If your battery dies while you are on a trip or tight budget, junkyards pull them out and sell the newer ones for like $25.
The starter draws 1800 watts, and for a split second can draw 400 amps or so, due to the "in-rush" of the coil. So the larger CCA rating means a given battery will do a better job of starting the truck on a cold morning. Trucks that are parked outside in the wind chill have a tougher time than those that live inside a garage.
![Smile](https://landroverforums.com/forum/images/icons/icon7.gif)
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
