Disco Headlights, and wheel trim plastic!
Old Jul 31, 2008 | 02:44 PM
snowdude's Avatar
Default Disco Headlights, and wheel trim plastic!
my 03 disco has no mechanical problems with 93k miles, but a few cosmetic problems that really annoy me. both head lights fog with condesation when its even slightly humid, and the wheel plastic fenders have faded from dark smooth black, to ruff smoke grey. dose anyone know a easy way to fix this without spending alot of money? or has anyone had these problems and got them fixed?
Its usally worse then this,
usally the whole headlight.
both headlights do this, right
is worse, do you think they
arent fitted correctly?
the right side is worse the the left, the tires and fenders
used to be the same color.
Old Jul 31, 2008 | 03:04 PM
Disco2Guy's Avatar
Default RE: Disco Headlights, and wheel trim plastic!
The condensation is a common issue with the newer style headlamps.
Old Jul 31, 2008 | 07:24 PM
bearcatfans's Avatar
The dealer put 'drain tubes' into the bottom of both of my headlights which cured my water problem....check here for the wheel arches.....
https://landroverforums.com/m_61006/tm.htm
-aaron
2003 Disco SE7
Old Jul 31, 2008 | 07:55 PM
Your headlight seals are bad/leaking. Common problem. Do a search on this forum for the answer.
Old Jul 31, 2008 | 07:56 PM
As for the wheel arces, you just need to buy new.
Old Jul 31, 2008 | 07:59 PM
Sorry, just check the link, maybe you can buff them out. (wheel arches)
Old Jul 31, 2008 | 08:52 PM
brooksa's Avatar
I had the same problem with my passenger side HL, I took it out and used a hairdryer to dry it out. Haven't had any problems since (knock on wood). As for the arches mine are doing the same thing??
Old Jul 31, 2008 | 09:12 PM
If you want to replace, then check out Rover Connection...they have all six new as a set for $400..
http://www.roverconnection.com/Disco...rch_Flare.html
-aaron
Old Aug 1, 2008 | 08:28 AM
okdiscoguy's Avatar
wheel well stuff. Try this before you replace.
http://www.roverparts.com/Parts/9313.cfm
skatelove303
Jul 20, 2010 06:42 PM
DiscoWest
Sep 23, 2009 10:15 AM
yarddawg
Jun 14, 2009 04:50 PM
Barron2032
Jan 7, 2009 11:12 PM
