Disco I 94: Window Regulator or Motor?
I brought my disco 94 into my mechanic(non land rover) to try to fix my front passenger and driverside window.. he ran an electric test he told me that he believes the motor is dead and told me to find one at a salvage and he would put them in... However I have heard this problem could be a regulator problem as well. Is it possible to find out if the window problem is a regualtor or a motor.. I would hate to buy one and it be the problem with the other.. Also does anyone have pages scanned from the land rover fix it manual dealing with the window? can someone also list some good land rover salvage companies that I could call to find these parts..
Cheers,
zb
Cheers,
zb
First things first. it is probably the regulator on the window. It is not that frequent that the motor will fail. Without taking the door panel off there is little way of telling exactly what the problem is. You did not say wether the window was working or not. The regulator has a pair of polyurethene wheels that ride in the window track. they wear out. usually a flat spot on the wheel. Make sure what the problem is before you buy parts. Even used rover parts can be expensive. What i first suggest you do is get either a haynes manual or the land rover shop manual. The procedure for replacing the regulator is not difficult. it is a pain in the butt. Not alot of dissassembly but difficult to reach bolts and figuring out the right angles to put you hand and getting the regualtor out. Places to find parts for disco's. There is a list in the search section of the forum with business and web sites. They are a good place to start. Do a general net search for land rover parts. The most expensive place is the dealer. If you do buy used parts and they are not the problem make sure you can return them if they are not the problem. The key to the rover is maintanence. Get it right, keep it right, and fix theys as they happen. Use the forum for solutions and advice. Do as much on your rover as you can. you will get to know the vehicle. mine is a 96 disco. 130k and still going strong. hope it helps. Gotta love a rover. duboff
Al Blue4.6l
08-14-2011 05:28 PM
bcolins
10-20-2008 10:52 PM
