Disco II Cargo Door Stuck
Lock mechanism with the motor in it is probably failing.
I would replace that.
You can try to pull up the locking mech lock/unlock tab at the window sill and see if you can unlock it that way.
Then manually use the outside handle or the inside handle.
But you need to replace your lock mech asap.
