Just thought that I should replace the rusty bolts that are on it now...pitting etc. Figured if someone knew the size then I could skip paying the dealership a couple bucks per bolt for the same bolt I could pick up at the hardware store for a few cents...just a thought.
Even if the thread is from 2008, it's better to bump than start a new one
Duo taptite M10 x 25mm
Probably won't find those at any hardware store. They have special threads for higher strip-to-drive ratio and higher prevailing torque
Wait until you pop one of the tack welded nuts off the underside of the lower shock mount, and have to replace with a new loose nut that you can barely get a wrench on...
