Disco II front shocks lower mounting bolts
Old Sep 10, 2008 | 02:43 PM
cptshanman's Avatar
Default Disco II front shocks lower mounting bolts
Anyone got the size of the two front shock lower mounting bolts?
Thanks,
Shannon
Old Sep 10, 2008 | 05:48 PM
Default RE: Disco II front shocks lower mounting bolts
Not without crawling under the truck and getting dirty. Why are you asking?
Switzer's Avatar
I installed a 1 inch Toddco lift on my Rover and it included new bolts. Email Toddco and ask them what size bolts they include in the kit.
http://www.toddcosuspensions.com/
Cheers,
Pete
Old Sep 10, 2008 | 08:17 PM
cptshanman's Avatar
Just thought that I should replace the rusty bolts that are on it now...pitting etc. Figured if someone knew the size then I could skip paying the dealership a couple bucks per bolt for the same bolt I could pick up at the hardware store for a few cents...just a thought.
Old Sep 20, 2017 | 10:01 PM
LandBeard's Avatar
Bump. Ever get the bolt spec?
Old Sep 20, 2017 | 10:18 PM
Jeff Blake's Avatar
Even if the thread is from 2008, it's better to bump than start a new one
Duo taptite M10 x 25mm
Probably won't find those at any hardware store. They have special threads for higher strip-to-drive ratio and higher prevailing torque
https://www.lrdirect.com/KYP500250-Bolt/
50 cents here.
Old Sep 20, 2017 | 10:30 PM
LandBeard's Avatar
50 cents here.
Cheers! Mid lift install and figured I'd replace the hardware.
Old Sep 21, 2017 | 12:32 PM
MacRoadie's Avatar
Wait until you pop one of the tack welded nuts off the underside of the lower shock mount, and have to replace with a new loose nut that you can barely get a wrench on...
xxjtvxx
Aug 24, 2016 08:11 PM
Dan7
May 1, 2013 10:35 AM
gundog
Mar 18, 2013 09:18 PM
cassidyrj1
Jan 7, 2011 07:33 PM
Robover01
Aug 5, 2009 02:32 PM
