Disco II Oil Leak
I have an 02 Disco II with 105k miles. Had oil leak start around 90k while under warranty. Dealer replaced oil pan gasket, valve cover gaskets, head gaskets, rear main seal, front seal and cross "crucifix" seals. It has continued to leak after every change. It will leave a spot about two inches in diameter every night after being driven. I looks like it's coming from somewhere around the starter and dripping somewhere from there. What other gaskets are there to change. Land Rover told me to take it back to dealer but this has been going on now for over 6 months with no resolution. any suggestions?
well the obvious question is "have you taken it back to the dealer? what did they say?"
if it has a warranty and a mechanical problem then THEY should be fixing it. I see that you are out of warranty mileage wise now but it was documented with them before it went out of warranty, correct?
Make sure your PCV (Positive Crankcase Ventilation) system is functioning properly and the breather tube and strainers on top of the valve covers are not clogged. If both systems are clogged, it will cause a leak at the main seals or valve cover gaskets.
Are you positively sure that the dealer replaced your rear main seal. Did they remove your transmission to get it done?
I have a bad feeling that they did not do the rear main and it is leaking there!!!
How much did you pay???
At the last trip to the shop in December, they say there are no other gaskets to replace. I bought this vehicle with about 50k miles and prior owner had not used synthetic oil, so I kept with what they had been using. After the first work LR dealer did, they put synthetic in. At next repair, they put the same oil I had been using. Said that synthetic could be causing it to leak?
thearmlesswonder
07-27-2015 10:16 AM
Phatrowles
01-09-2014 10:36 AM
