Disco II P300 and P308
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
If not fuel or oil, which would burn off with good spark, but you don't have spark. Certainly swap a plug or wire. If you have good spark, then coolant. Rear area of head gasket is slim by the outer cylinders, in particular the rear. Might be time to consider a mechanic in a jar product, like http://www.irontite.com/store/index....&products_id=2 . These products can work in a range of cases, but might not be a forever fix, and could cause problems if cooling system is partially clogged. I would think that if they are going to work, a small leak might be easier to have success with than a big leak.
So the rest of the partz vulturez can stop ruffling their feathers on the upper branches of the shade tree, it is important to note that it is not as good as a new head gasket, there are other tests you can run (like dye in coolant, which would show up as flecks of green on the plugs), and you may end up doing the head gasket and cleaning out the radiator.
0304Disco
09-24-2013 11:14 AM
