Disco II seat heater retrofit
Old Jan 16, 2007 | 02:23 PM
stanigu's Avatar
Default Disco II seat heater retrofit
hello
I've read that pre-2001 model Disco IIs have all the pre-wiring (including heating elements) pre-installed for seat heaters, and that all I have to do is to add the switches?
I have a 2000 SD model, with vinyl interior. Has anyone tried this? Almost sounds too good to be true....
Old Jan 16, 2007 | 03:35 PM
Default RE: Disco II seat heater retrofit
I don't think you will have it with thevinyl interior, only the leathers have it.
Sorry
Mike
Old Jan 17, 2007 | 01:10 PM
stanigu's Avatar
[:'(] Bummage. I knew it was too good to be true!
Old Jan 17, 2007 | 03:48 PM
JBRIII's Avatar
pull the panel and see if the wiring harness is there.Mine is an 02SE and had them, I have leather though.
Old Jan 17, 2007 | 03:58 PM
The wires may be there but if you don't have leather then there are no heating elemants.
Mike
Old Jan 17, 2007 | 04:38 PM
JBRIII's Avatar
good to know. I hooked mine up and finally got to use them as it's been in the 20's here. Definately a nice feature.
Old Jan 17, 2007 | 06:39 PM
Blatallic's Avatar
so my 03 SE Disco has pre-wired seat heaters??
Old Jan 18, 2007 | 11:33 AM
ORIGINAL: Blatallic
Yes, all you need to do is buy the switch kit and change them out.
Mike
Old Jan 18, 2007 | 12:43 PM
Blatallic's Avatar
REALLY, wow I saw a few switches on ebay....Think I may need your help on this one Mike
Old Jan 18, 2007 | 12:55 PM
Go to either Atlantic British or Rover Connection and order the switch kit, that way you will get all the necessary parts including the new trim plate.
Mike
