disco II starting problem/ camshaft sensor?
Old May 4, 2011 | 08:46 PM
culture1's Avatar
7th Gear
Default disco II starting problem/ camshaft sensor?
so truck just died on me at a light like the gas ran out? i could turn it over fine. fuel pump sounds like its kicking over. i could hear it. Took it to the shop and they ran the codes on it. They told me I needed a camshaft sensor? does this sound right to anyone. Want to charge $260.00 for replacement. Can i find this sensor affordably anywhere? Thanks for the help!!!!
Old May 4, 2011 | 09:00 PM
No it is NOT the cam sensor, it is the crank shaft sensor.
$65 part at your local autoparts store.
Read the write up section for a "how to" on DIY replacement.
Old May 4, 2011 | 09:12 PM
culture1's Avatar
7th Gear
Default Thanks mike!!
Appreciate the help..
Old May 5, 2011 | 03:11 AM
Livingintheskies's Avatar
x2 on the crankshaft sensor, same symptoms back in NOV. replaced and haven't had a problem since
Old May 5, 2011 | 03:17 AM
buick215's Avatar
X3 on the crankshaft sensor, besides I have never heard of a camshaft sensor going bad. If it is the camshaft sensor than it's $300 instead of the $65-$85 cost of the crankshaft sensor.
Old May 5, 2011 | 07:38 AM
I would be real careful when using that shop in the future, also if you ever go to have codes read, get the code number from them so you can check with us first and saving a lot of time and money.
Old May 5, 2011 | 09:32 AM
DiscoveryHouston's Avatar
Definately the crank case sensor. Its a cheap & easy fix, took me about an hour to do mine. Advanced Auto has the part for $30 something. Not sure if you have an Advanced Auto where your live.
KlamathMatt
Apr 17, 2020 05:27 AM
4Low
Sep 17, 2014 03:28 PM
studflucker
Dec 10, 2013 09:01 AM
jmccollister
Sep 9, 2008 08:50 PM
icoolyou
May 16, 2007 05:50 PM
