Disco II THUMPing... exhaust leak?
Old Apr 11, 2020 | 02:21 PM
Richard Gallant's Avatar
@treicruz
This a good engine result, you should be in the second range for a Disco 2 unless you have one of the weird low compression engines
Compression Check: Testing and Inspection
Compression Check
1. Start and run engine until normal engine operating temperature is achieved (thermostat open).
2. Remove all spark plugs.
3. Disconnect both coil negative leads
4. Insert compression gauge, crank engine until reading stabilizes.
5. Expected readings, throttle fully open, battery fully charged:
8.31:1 = 10.2-10.9 bar (148-158 psi)
9.35:1 = 11.5-12.2 bar (166.75-176.9 psi)
6. If compression is appreciably less than correct figure, or varies by more than 10%, piston rings or valves may be faulty.
7. Low pressure in adjoining cylinders may indicate a faulty head gasket.
samroy92
Jun 21, 2019 04:51 PM
RoverJay
Oct 27, 2015 04:38 PM
Racer X
Jun 13, 2015 10:40 PM
djdart
Jul 6, 2014 05:48 AM
anteyv
Jan 31, 2013 09:36 AM
