Disco II tire upgrade
I poked around in the archives but didn't see an answer for this one. I have a 2003 Disco with an Old Man Emu heavy duty shock and spring upgrade giving it about 2" of lift. I'm looking for a more aggressive offroad tire that will fill up the wheel wells a little more than the stock tires, but not something that is going to "howl" on the pavement. Running stock rims. Any suggestions out there for tire size and brand?
You could probably sell your used Bridestone's so you can included that if you decide to go for the Duratracs
You should have no issue with 31" tires, maybe a bit taller. Some great options for good off-road tires that don't drive you nuts on the freeway are the above-mentioned Hankook ATM and Goodyear Duratracs, Cooper AT3 and ST Maxx, General Grabber AT2, Pro Comp AT, and the good ol' BF Goodrich AT KO.
