Disco II wreck repaired now have multiple codes.
My wife was recently hit in the Drivers side front while stopped at a stop sign. Our Disco has now been repaired with all new parts but is throwing multiple SES codes & for the first time ever even has the SES Flashing sometimes but not for long.
I have a feeling it is the Drivers Side Pre Cat O2 Sensor due to codes & the fact that the engine was covered in fluids from the other cars involved. Also not sure why but it seems the Throttle Body Heater has developed a leak also now which I have already purchased the repair kit.
I am of course having issues with the Insurance on these codes since they don't think they could be caused by the wreck even though it was running GREAT before the wreck.
So thought I would post to see if anyone has any ideas or advice as to how to proceed.
Already have 2 O2s ordered & on way
Codes that have showed up are:
OBD2 Codes set
02/03/2011
P1300
P0305
P0130
P0303
P0301
PENDING:
P0301
P1129
02/01/2011:
3rd Set after reset by me
P1300 Boost Calibration
Po301 Misfire Detected
P0303 " "
P0305 " "
P0307 " "
PENDING:
P0134 O2 Bank 1 Sensor 1
2nd set 5:47 PM after reset by me
PENDING:
P1412
P0300 Random/Multiple Cylinder Misfire detected
P0307 Cylinder 7 Misfire Detected
P1129 Downstream Heated O2 Sensors Swapped
1st set after reset by Shop
P0305 Cylinder 5 Missfire Detectected
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
PENDING:
P1412 No description
01-31-2011
P0130
PENDING:
P1129
Thanks in Advance
OBD2 Codes set
02/03/2011
P1300
P0305
P0130
P0303
P0301
PENDING:
P0301
P1129
02/01/2011:
P0303 " "
P0305 " "
P0307 " "
PENDING:
PENDING:
P1412
PENDING:
01-31-2011
P0130
PENDING:
P1129
Thanks in Advance
P1412 Secondary Air Injection System – Malfunction Bank 1 LH (Insufficient SAI flow
during passive test)
P1129 O2 sensors swapped bank to bank (sensor 1) Front sensors transposed
I'd swap the sensor connectors and see what happens... and check for anything else that doesn't seem to be plugged in right.
Think think the flashing SES light means a severe misfire, and you probably shouldn't drive it like that. What all was damaged and replaced?
Outside:
Bumper,
Brush Guard,
Fog Lamp,
Headlamp,
Headlamp Finisher,
Drvrs Fender,
Splash Guard,
Flare,
Windshield Plastic panel at bottom.
Intake Hose (Replaced by me due to Adjuster saying it had glue on it which I later found out it is glued from factory)
Inside:
Dash Cluster was knocked loose breaking the clips
Rear Cup Holder was broken out by our dog somehow
Drivers Headrest Seat Lcd was knocked out breaking the plastic bucket.
Thanks for the advice
Final Out Come is what I thought it could be.
Bank 1 Sensor 1 O2
Now of course the Land Rover Dealer didn't like my after market wires & plugs & first tried to blame them. The insurance adjuster almost had a coronary when they told her $810.00 for wires & plugs which wasn't actually needed.
Lesson to be learned here never trust the dealer they are out to get us for all they can.
Running like a champ now although I still don't understand why a vehicle that supposedly can go into water can't have moisture get on the O2s.
Thanks for the replies.
Bank 1 Sensor 1 O2
Bank 1 Sensor 1 O2
Bank 1 Sensor 1 O2
Just a guess, but maybe there was a break in the wiring cover or loose connector from when they did the repairs and at some point water got into the sensor?
madherm
Feb 28, 2010 08:44 PM
