Disco question
I'm not aware that the speedo can be calibrated. It has most to do with the tire size on the vehicle. I'm running 255/60-18's which are about 1" taller than the stock size of 255/55-18. My speedo is right on the money with this size.
I used one of these 'calibrators' on a prior rebuild. Worked fine (on an Alfa). Just used a friend driving next to me to calibrate....
https://www.dakotadigital.com/index....D=115&mode=cat
I find a GPS Speedometer on my phone very helpful. I have oversize tires that make the dash speedometer right on up to about 30 MPH - but it's off again at 75 MPH and about 5 over what the dash says.
i took a chance, pulled the speedo needle off the cluster, drove using the gps on my phone. at 40 gps speed, pushed the needle on the gauge . a few attempts later got it on the money. road tested at various speeds. cheap fix worked for me.
