Disco radiator
Old Jul 20, 2018 | 06:02 PM
redwhitekat's Avatar
Default Disco radiator
my rad is leaking on the drivers side where that screw that hods the bracket goes into rad
I did just buy a 99 disco for parts but not sure if I want to put in that old rad
my question is are the rads from rock auto any good and durable ?? My local suppliers want $760 plus tax here in Canada
Old Jul 20, 2018 | 06:22 PM
Speedsterguy's Avatar
Buy a $50 radiator from Ebay They work great and I have had zero issues
Old Jul 20, 2018 | 07:53 PM
Saturnine's Avatar
This.
This is the rad i bought for MagPie and its been working just fine. Even if it turns out to be sh-t, i'll just buy another because.. its $60.
https://www.ebay.com/itm/35192142814...&s=ci&mail=sys
Old Jul 20, 2018 | 07:57 PM
Thanks yes I see that seller they have same rad few different prices one is $98 other is $115. Ships from Canada no fees.
I think I will give them a try.
Old Jul 20, 2018 | 07:59 PM
Saturnine's Avatar
Can't really lose fo that price honestly.
Old Jul 20, 2018 | 08:02 PM
Best4x4's Avatar
Yep all the cheapie radiators I’ve used and installed have worked out great. Small tip on the re-install. Take the screws that secure the lower shroud to the radiator (where you usually get leaks) and cut off like 1/4 of an inch off of them! They will still hold the lower shroud, but they shouldn’t go to far & put a crack into the plastic radiator tank.
Old Jul 20, 2018 | 09:12 PM
thanks for the tip
Old Jul 20, 2018 | 09:13 PM
Best4x4's Avatar
No problem at all!
Old Jul 26, 2018 | 12:30 PM
Installed my eBay radiator today not a bad job hopefully it lasts
Old Jul 26, 2018 | 01:10 PM
ahab's Avatar
Mine is on its way!
