disco want make a sound
Old Jun 22, 2009 | 06:52 PM
bowtiecb's Avatar
Default disco want make a sound
i replaced the fuel pump on my 98disco, pulled the neg cable on bat, once i got thru replacing the pump, hooked the bat back up turned the switch, lights came on but it wouldnt make a sound. whats the deal. thanx corey
Old Jun 22, 2009 | 07:20 PM
What wont make a sound? The fuel pump? The engine wont turn over? Wont start? What?
Old Jun 22, 2009 | 07:36 PM
98roverguy's Avatar
Why did you replace the fuel pump to begin with? You need to be more specific.
Old Jun 22, 2009 | 09:02 PM
bowtiecb's Avatar
replaced the fuel pump because it went bad,unhooked the bat cable to install the fuel pump, once i was done,hooked the cable back up, tryed to crank up the truck and it would not turn over. tryed the unlock 3times thing did not help. but right b4 i unhooked the bat. it would turn over but not crank
Old Jun 23, 2009 | 08:09 AM
Pump probably wasn't bad, that is the problem with replacing parts like you know what your doing without asking for help first.
If you spray carb cleaner into the t/body, reinstall the hose and try to start the engine, will it start?? Does it have spark, did you check the fuse and has the fuel relay been replaced?????
Old Jun 23, 2009 | 03:20 PM
It would turn over but not start, cranking and turning over are the same thing.
Like Mike said, check for spark first.
Old Jun 23, 2009 | 06:22 PM
bowtiecb's Avatar
if you mean not used to workn on rovers, by saying not knowing what im doin then u r right, i sprayed starter fluid in the tb first thing. started instantly, i did not hear the pump pumpn, so i assumed the pump was bad after i checked the fuse under the hood. now the relay i did not check and to my knowledge has never been replaced.thats stuff i did b4 i even posted cause to me thats common sense to check first. now after i tooked the cable loose for a couple hours it turns over but want start.
Old Jun 23, 2009 | 06:35 PM
bowtiecb's Avatar
let me start from the begining.truck started cut out a 70 mph some times bout two weeks a go, i thought it was bad gas. so sat my wife was drivn and she said it flt like was running out of gas so she filled up,started comming home,pulled a hill and the car shut off.so i walked to the car started the car, and i can hear the pump sounded real weak,droved the car about 100 yards and it sputterd home like the pump was going out.cut it off, tryed to start it and it would not start. installed a pump and now still wont start im go check and make sure its getn power to the back, and let yall know.
Old Jun 23, 2009 | 09:26 PM
Sounds like a clogged $15 fuel filter.
You can buy a new one at Wal-Mart.
It is behind the rear passenger wheel bolted to the frame.
Old Jun 23, 2009 | 09:34 PM
bowtiecb's Avatar
changed it bout a month ago, got one from oreillys,i think it might be a bad pump,gettn 12.8? at volts at the pump on purp/wht and black wires with the key in on position, but the pump still not comming on
