Disco window regulator
Old Apr 2, 2015 | 11:04 AM
hankeester's Avatar
Default Disco window regulator
So I took the door card off and saw a mangled regulator, the arms were all bent up because the rollers broke. I ordered a new one from AB and am wondering what the process is for the re-install. Does the gear part have to be in a certain position when I reinstall it? It was pretty straight forward taking it out but I couldn't get a visual on how it fit because the arms were so bent up.
I ordered the new rollers from a forum member that is selling them on Shapeway and will do my pass. side window after I do the drivers side. The pass. side still work but isn't horizontal when first opening it so I'm pretty sure the regulator is still good, just have to replace the rollers.
Old Apr 3, 2015 | 06:13 AM
zski128's Avatar
No, the gears dont have to be in a certain position, just reattach the motor. There are a few write ups with pictures on the site for this procedure. In my case my motor had broke and I didnt know this, the window wouldnt roll all the way up. Get a good set of panel poppers and maybe a couple of the plastic studs for the door card. Be careful with the door card, its made of foam and can crack if you are too rough. Its easily removed with the window all the way down. Also, the black window sweep on the top inside of the card is a little tricky, pull it out evenly or else you will kink it and will look like crap when you reinstall.
Old Apr 3, 2015 | 09:37 AM
hankeester's Avatar
Thanks for the feedback. I'll keep an eye on the window sweep. I ordered new panel plugs from AB but ended up getting the door card off without any breakage issues on the plugs. Regulator will be in tomorrow, right now using the ole' screwdriver to keep it at half mast. I will then tackle the pass door with just putting the new 3D printed rollers on the arms.
Prost.
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
zachbraff
Jul 18, 2005 12:57 AM
