Which disco year to buy?
Okay so this will be my first Disco. Can someone tell me which model year i should look for and what to look for when checking out the car? Anything regarding past service i should look for in a car fax?
This is the one i am considering!
http://www.cars.com/go/search/detail...5&aff=national
Thanks!!
Thanks!!
Maintenance records are important unless it's real cheap and you don't mind putting time into it, watch out for the serial numbers on the 2003 theres a bunch to stay away from (vin's affected here http://www.landroverclubvi.com/oil-gauge.html) Whatever you buy your on the right forum, lot's of knowledge, lots of tech help and some poking fun too! Read discomikes sticky on the 60k service, and preform it on whatever you buy no matter the mileage or what the owner says has recently been done....as I believe spike said " it wasn't done unless you did it" or something to that effect.....
Driveable? I guess it means how driveable....I would say no. ABS pump used about $250, new MAF sensor $150 from roverguy.com, and $100 for the ICM. As for labor costs, it depends on what type of shop you rely on....if you have a good independent, then plan on $300 (give or take). But all of those things should be done before it's driven very much. I would think if a "dealer" has this truck for sale, then he's just trying to move it quickly "as-is" and probably stole it for cheap on trade-in, as the previous owner did not want to deal with the issues.
So I am settling on one. The dealer reports it needs a ABS pump, idile control mod and a mass air flow sensor. Are those common issues for a 2000 with 116k miles. How much should I expect to pay on labor to replace those? Is it drivable in case I want to wait on those repairs??
Definitely get a series two, like the other guys said. Don't be in a hurry, take your time and look at a lot of them. You can basically see everything that you are getting into by looking through the forum, just keep in mind that they are completely worth it once you get the small things corrected. Good luck in your search
