Discovery 2 Operating Temp
Hi everyone,
A while back I purchased an Ultragauge for my 03 Discovery and had issues with it running 212-221 when driving. A coolant flush revealed that the Dexcool had turned into sludge. I flushed and replaced the thermostat in my truck and all is good. Even in 90 degree temps. I am curious as to what a safe operating temperature is. I am aware that the 03s in particular are prone to slipping liners when overheated. What temperature would you guys consider "overheating" without looking at the stock gauge? I typically am seeing 188-195 during the winter but have seen it go up to 208 in the summer. Is this a cause for concern or is this normal?
I should have specified that I do have a 180 tstat installed. I am very nervous about the engine temps lol. I ran the truck with the temps in the 212-220 range without knowing for over a year so I guess no harm was done, but I do not want to deal with a head gasket issue. Especially because mine is on its original set with 128k miles, somehow. It doesnt lose any coolant at all either, it is a miracle. 😂
220 was the original operating temp but overheat is 240ish and it will get there fast if there is an issue. In 105 deg temp 15-20mph up a 12-14% grade for 20 minutes mine hit 215-217 at the hottest with the inline 180 - 164 on down hill on the other side. Stock gauge never budged.
Normal for me 183
Normal for me 183
Does the Disco like it better at 170-180? I seem to remember hearing that those temps may cause emissions issues? I've been shooting for 180-190 with my mods, but if it'd be happier even cooler, maybe I'll go ahead and get another thermostat. I assume the ones in the Extinct kit are BB Chevy stats?
adalton (02-09-2022)
Two facts with the Disco 2 operating temps. Number 1 - anything under 210 is absolutely fine. Number 2 - Extinct's inline thermostat is the best upgrade you can do for your truck. I always thought I was fine with a 180 factory style thermostat. I was wrong. The inline setup is far superior. #facts.
Mntnceguy (02-10-2022)
I run 170's in my 00's and get 17 mpg consistently. The 03-04's will throw a code if you run lower than 180, but they have 4.6's so not fair to compare mpg apples to apples. I have seen no negative to running down at the 170 level. The Chevy stats will work, really any of the standard 2 1/8 stats will work which were used in a lot of vehicles. SBC might resonate with your local parts suppliers although it needs to be the 70's models so they are not a bypass thermostat model.
