Discovery 2 questions......
Old Jan 21, 2020 | 08:26 PM
Deathmedic1's Avatar
4th Gear
Default Discovery 2 questions......
Ok guys I have some questions about my rover, it is a 2004 disco 2 with 98000 miles. We just recently acquired it with a blown right side head gasket. The motor was studded and new gaskets,water pump,all cooling hoses were all done last month and it is driving great.
So here it the questions,
. (1) I have read about the front driveshaft rebuild/replacement but can anyone explain to me the signs of the shaft wearing out?
. (2) rear driveshaft flex coupling when should it be replaced?
. (3) I am planning on keeping this rover till it falls apart.( which in It's pristene condition will be quite some time) so with that being said is it recommended to purchase a nanocom to help service the truck and get rid of the damn three amigos and power flush the brake system.
. (4) Is there anything I am overlooking besides a transmission service?
Thanks in advance for any pointers you guys can give me.
Old Jan 21, 2020 | 08:38 PM
Best4x4's Avatar
Get a driveshaft with zerk fittings and pump grease into it at every oil change. Rear Rotoflex is easy to swap and they honestly hold up very well. If it's severely cracked = replace it. You do not need the Nanocom to power bleed the brakes. 10.00 worth of wire and a toggle switch = you can power bleed the brakes vs a 500.00 scantool/programmer.
Old Jan 21, 2020 | 09:54 PM
redwhitekat's Avatar
My advise is research this forum almost everything has been covered
I would do maintenance first including coolant switch to green , cooling system temperature constantly monitored via ultraguage or similar
new 180 stat
Old Jan 21, 2020 | 10:06 PM
Discorama's Avatar
Front drive shaft is very critical. It can get expensive if it fails (can tell you from own experience).
Old Jan 22, 2020 | 12:19 PM
XRAD's Avatar
Sorry, gonna need some pics of this pristine vehicle!
Old Jan 22, 2020 | 12:20 PM
whowa004's Avatar
Best, any write up on the cheap power bleed method? First time I'm hearing of this somehow.
Old Jan 22, 2020 | 02:54 PM
XRAD's Avatar
just cranking the ABS pump?
Old Jan 22, 2020 | 06:40 PM
4th Gear
This was just after i bought it off a private individual, and no I did not clean it up at all... the only problem is the headliner drooping around the front sunroof.
Old Jan 22, 2020 | 06:41 PM
Extinct's Avatar
Yes, ABS pump relay jumper. Do the PCV mod. Pre-emptive radiator and expansion bottle replacement woudl be a good idea. Run 15w40 diesel oil only, FL1-A oil filters. If your headliner is in good shape pull it down and fix the sunroofs or you will wind up needing a new one due to leaks.
Old Jan 22, 2020 | 09:29 PM
tylerhardie's Avatar
Nice! Great purchase. Get an Ultragauge and monitor those temps... Front prop shaft if it hasn’t already been done. They are such fun trucks. Congrats!
