Discovery 2 TD5 cold start problem
Hi, I'm new to this forum but hope that someone can help. I have a 2003 TD5 which I have a problem starting in the cold. I live in the Swiss Alps and when the weather gets below about -8 c the vehicle doesn't like to start. I have had the glow plugs changed and a new battery. Once the car has started there is no problem re-starting it and when the weather is warmer it starts no problem. I have tried leaving a hair dryer running under the bonnet for about 1 hr which seems to do the trick!! Is there something more appropriate on the market to pre-warm the engine? Cheers, Dan.
You can get a block heater, most diesels have them already, if not they can be had at a diesel parts supplier or the dealer will have them for sure.
There is also a heater that you can buy that goes into the lower radiator hose and heats up the engine coolant.
Another thing to consider is the condition of the fuel filter and the quality if the fuel, a partially clogged fuel filter or low quailty fuel can cause hard starts when cold.
http://www.roversnorth.com/store/sea...m=block+heater
Just to give you a idea of what I am talking about.
And here is some info on cold weather starting.
http://www.kenlowe.com/pre-heaters/cars/whatwill.html
I looked at your link to Rovers North for the block heater but they are obviously a 110V supply for you guys and not the 220v that we have here. I traced one on a UK site and gave them a call for more info, the chap didn't know anything about it but called back later. Apparently it was a product only for Canada for their Freelander service vehicles. Anyway the same site can supply the Kenlowe pre-heater unit so I think that is what I shall try. I probably won't get the unit for a few weeks as I shall pick it up next time I'm in the UK but I will let you know how I get on fitting it and well it works.
