Also I guess I was having a hard time posting pictures on this thread and on my third attempt I realized the moderator had to approve them... so be expecting multiple posts I’ll delete them once they post.
I honestly toss the screws those come with & use black drywall screws. They bite into the plastic MUCH easier & they sit into the trim piece perfectly flat. I’ll be doing my 97 XD’s dash this weekend when the kit comes in. Normally takes me 30min to install.
I just glued my warped dashbord. When it's hot and sunny and the car is parked in the sun, the dashbord gets quite soft. I used a heat gun in addition and it got very easy to push it down. I used Aquaseal, which is an urethane glue (pls see below). To get the glue underneath the dashboard I used a syringe with a thick bent needle. When the glue is warm, it gets very fluid and can be pushed through the needle. Letting the tube sit in the sun for a few minutes is sufficient. The heat gun can be used to heat the glue up more, especially the glue in needle.
