discovery vibration above 70mph
Old Jan 18, 2007 | 05:12 PM
shagybruce's Avatar
Default discovery vibration above 70mph
I have a 2003 discovery se and have noticed a bad vibration above 70 75 mph. below that all is well, i have heard of driveshaft problems and even flex ring problems is this something that others have noticed? and what was the cause and correction and do lr still cover this ? i have 50,000 on mine
Old Jan 20, 2007 | 07:10 PM
Landzu's Avatar
Default RE: discovery vibration above 70mph
Mine was the flex ring just in front of the diff.
You can replace the rubber u-joint (flex ring) or get a
replace the driveshaft that has a real u-joint for about
400$ that is what I did.
Old Jan 20, 2007 | 09:15 PM
shagybruce's Avatar
i took a good look at those today, both seem to be fine (no cracks or splits and no sloppiness)i know that it has been just fitted with new tires before i bought it. could the wheel/tire balance be out that much to cause this. i know it has 18"tires that i guess would accentuate any imbalance. any other people experience wheel balance vibrations. itjust seems the whole vehicle is shaking...kind of unnerving when the wife drives it...thanks
Old Jan 20, 2007 | 11:56 PM
1eyescooter's Avatar
I too am having a similar problem where mine wobbles at 50 and when I hit bumps in the road. I have to get this fixed as there are more pertinant things to fix on my 96 Disco. However if you back track in this forum to 9/2/2006 at around 1:56 EST there was a two page post with multiple ideas of what could be wrong and how to fix it, including balancing the tires. The thread is named STEERING WOBBLE. Hopefully you can get some information from it since all of the veterans were the ones with the advice.
Nikki
Old Jan 21, 2007 | 11:24 AM
ORIGINAL: 1eyescooter
Nikki
Nikki,
Sounds like you have either some bad bushings, a bad tie rod end, a bad steering stabilizer or you need to get your preload set on your swivels.
Mike
Old Jan 21, 2007 | 11:54 AM
ORIGINAL: shagybruce
I would start with having your tires rebalanced, you will probably find the problem there.
As for your front drive shaft, are you under warranty, if so don't worry about it for now.If you are not covered by a warranty have someone rebuild your front constant velocity joint other wise it will fail and you could be looking ar a new tranny also, VERY $$$$$.
Mike
Old Jan 23, 2007 | 10:15 PM
shagybruce's Avatar
I had the tires balanced yesterday and its amazing the difference...no more vibration....the tire guy said it looks as though the last person who balanced them was out about 180 degrees with the weights...now the only thing i have is a kind of oscillating wirring noise from below...its not really bad but it seems to get faster the faster i go...maybe a u joint? or is that just a normal sound....also when i pull away from a standstill the trans kind of whines but i dont get any banging into gears and no trans slop...normal again? it only happens fron 1st to 2nd...thanks
Old Jan 24, 2007 | 09:56 AM
werldcup's Avatar
I had the exact same problem on my disco... Turns out I lost a couple wheel weights on the trail and a quick balancing fixed it right up.Situations like thatreally add credence to the in-tire balancing products.
Old Jan 27, 2007 | 06:48 AM
kylle08's Avatar
ORIGINAL: Landzu
Maybe you should purchase a high quality U-joint. That was what I did when I was in that situation same as yours.
ATXDisco
Sep 18, 2021 11:26 AM
LADEROUTE
Sep 18, 2021 09:59 AM
Hawkeye712
Jul 21, 2015 06:59 PM
charles21
Dec 6, 2010 04:53 PM
whurst79
Sep 14, 2008 02:41 PM
