Diso II '99 Chirping when accelerating in gear
Old 05-28-2006, 01:12 AM
Default RE: Diso II '99 Chirping when accelerating in gear
ORIGINAL: duboff
if the chirp gets higher is increase in throttle. spray the belt with belt dressing. if that is not the problem, take the belt off, restart the motor after it cools. if the sound is gone then the problem is in one of the pulleys. my first guess is the tensioner. I had a similar problem and tighten the tensioner bolt and the problem was fixed. the problem was cause by take the belt off when it was replaced I didn't tighten the mounting bolt on the pulley. With belt off it should help in the trouble shooting. hope it helps. gotta love a rover. duboff
If belt dressing stops the noise and all the pulleys and tensioner are good, replace the belt, don't depend on belt dressing to stop it for long.
Mike
Old 11-06-2006, 02:42 PM
tbesselman's Avatar
needed to replace the U-Joint.....noise gone...Thanks!
Arizona man
05-01-2011 01:42 PM
starrock
05-22-2010 08:39 PM
dhaselhorst
05-20-2010 09:57 AM
666
05-15-2009 08:04 PM
xadamx
01-21-2007 02:52 PM
Quick Reply: Diso II '99 Chirping when accelerating in gear
