DIY bleeding ACE system
Old Jun 2, 2014 | 03:21 AM
Richard Moss's Avatar
Default DIY bleeding ACE system
After replacing my leaking front ACE actuator, the workshop manual tells me that I have to get it bled by the Testbook system (which will be dealer only). Is there any way to DIY it or will I have to spend more money?
Thanks
Old Jun 2, 2014 | 04:03 AM
acg's Avatar
acg
I have the Nanocom Evolution programming unit which is great for DIY projects for the Disco. It has similar function to the dealer's Testbook unit. It is worth the investment in my opinion:
Home Page
Excerpt from the Product page:
SLABS (combined Self Leveling and ABS system)
As well as the expected reading and clearing of faults, settings pages, Inputs and Outputs, you can also calibrate the Suspension and store the new heights. Note that the ECU will not allow individual corner calibration, only the Left and Right sides. There is also a bleed function for the hydraulic systems.
Lucas ACE (Active Cornering Enhancement)
This ECU was designed to help improve cornering issues found in the Discovery 1. The Nanocom Evolution has the ability to read and clear Faults, View settings, View Live data, check outputs and also bleed the ACE system.
Old Jun 2, 2014 | 10:21 AM
dusty1's Avatar
might be worth a read
Land Rover Owner • View topic - TD5 has wind!!!
Old Jun 2, 2014 | 11:50 AM
Dusty1 that is EXACTLY what I need - you're a star. I don't have the testbook/Nanocom or whatever but I may be able to get the air out of the system by getting the ram to extend/contract by moving the bar.
Old Jun 2, 2014 | 12:29 PM
dusty1's Avatar
np. I don't have that fancy stuff either. I flush my ace with a turkey baster, starting, and rocking the truck side to side.
do wish I could program key fobs, though. I tried that same technique, but it didn't take
Old Aug 20, 2019 | 09:13 AM
Rovermike14's Avatar
8th Gear
do you still have this info? i need to bleed my new rear sway bar actuator thanks
The wanderer
Aug 18, 2022 07:04 AM
TRIARII
Feb 6, 2014 12:05 AM
drowssap
May 16, 2011 07:41 PM
05gixxer
Mar 12, 2009 04:42 PM
jycsalas
Dec 17, 2008 11:00 AM
